Knowlden's avatar
Knowlden
Follower
Oct 14, 2020
Virgin media hub 3 and WN1000RP
Hi, i had a virgin media hub 2 for a while and it worked great with my WN1000RP, i have had to swap to the hub3 as the old unit failed but this new hub3 cannot pair with the wn1000rp either automaticaly or manualy, I work in telecoms so am pretty happy with how these things work, the big issue as far as i can see is that the wn1000rp cannot see the hub3 i can confirm this from the netgear web app as i can log into the wn1000rp, but all other wifi enabled devices can see both (laptop tablet phine and smart tv) also the hub3 cannot see the wn1000rp to add manualy, i have done all updates possible on the hub 3 and even factory reset both devices and still nothing, the only thing i cannot do is a potential firmware update on the wn1000rp if it is needed, i have talked to virgin media for over an hour on this and they have no advisories that the wn1000rp + hub3 is a problem but their next action would be to send someone to site ????? so any help from here would be great.
thanks in advance.
Ned
No RepliesBe the first to reply
