× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Voyant client clignote sur repeteur AX1800 EAX15
Verrier57
Guide
Bonjour, le voyant client n'est pas stable. Il passe de façon aléatoire de vert à orange. Quelle peut être la raison ?
Message 1 of 11
Victoria96
Re: Voyant client clignote sur repeteur AX1800 EAX15
I have the same question as him. dinosaur game
Model: A6100|WiFi USB Mini Adapter
Message 2 of 11
Guru
which light? there's several LED's on it and each mean something different.
the manual goes over what they mean.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 3 of 11
Verrier57
Guide
It's the Client Link LED. Sometimes green, sometimes Orange.
Message 4 of 11
Guru
the client link led tells the strength of the connected phone/tablet/pc/laptop.
The client link led is going to vary because devices move around. so sometimes the device connected will be closer and have a stronger connection versus other times its further away so a weaker connection.
Message 5 of 11
Verrier57
Guide
OK Thank you.  It means that if there are 5 ou 6 connected devices at home, as long as one of them is too far from the AX1800, the client link led turns orange. That's right ?
Message 6 of 11
Guru
Not 100% on what device it displays for the led.
But you can log into it through the browser and check connections
Message 7 of 11
Verrier57
Guide
Thank you. I don't understand the first sentence : "Not 100% on what device it displays for the led".
Message 8 of 11
Guru
I'm just saying that i'm not sure exactly how the extender determines (if you have more than 1 device connected) which device it'll display on the led or if it cycles through them all.
Message 9 of 11
Verrier57
Guide
Thank you. That's the question I must find an answer. The netgear support must have this answer.
Message 10 of 11
Guru
You can log in through the browser and see each devices connection
Message 11 of 11
Discussion stats
  • 10 replies
  • 1270 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
