Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WAG102 LAN issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
05:54 AM
2012-08-30
05:54 AM
WAG102 LAN issue
I've just buy a brand new WAG102 and setup it easily but after one hour it loose its LAN connection and no LED except the power LED that was still ON
After having powered it down and on several times it restart for few minutes and fall down again
The LAN (100 Link ACT) LED now is never on (i've check and use the netgear cable and the 've check the network plug also)
I've try to reset it (by pressing the reset button for more than 10s) but it looks that it do not take it into account.
HOW can i solve this issue
Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
05:59 AM
2012-08-30
05:59 AM
Re: WAG102 LAN issue
May want to try different power supply if you have one just in case some power related issues causing it .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:01 AM
2012-08-30
06:01 AM
Already try diffrent one and also try to use PoE
Another lead?
Another lead?
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:09 AM
2012-08-30
06:09 AM
Poe was original setup? And tested regular power supply as well?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:13 AM
2012-08-30
06:13 AM
no initialy it has been setup using teh power supply kit provided with the device and then setup on POE and after the first issue
put it back on power supply with no more effect and retry the PoE with no success we are back on power supply
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:23 AM
2012-08-30
06:23 AM
sounds like you got bad poe injector if you are not using Poe switch
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:25 AM
2012-08-30
06:25 AM
No we are using a cisco switch no POE injector
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:38 AM
2012-08-30
06:38 AM
retry the PoE
So did you use PoE injector since you said you did not have PoE capable switch ?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:44 AM
2012-08-30
06:44 AM
No we have Cisco switch taht include PoE feature no need for PoE external injector
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:45 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
06:48 AM
2012-08-30
06:48 AM
I wasn't quite sure your reply so I had to ask
it maybe possible that IEEE802.af support issues
http://en.wikipedia.org/wiki/Power_over_Ethernet
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
07:20 AM
2012-08-30
07:20 AM
OK but it is the same using the power supply
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
07:39 AM
2012-08-30
07:39 AM
Not really sure if this was right...
You must wrote wrong on this one.
if both are having an issues then I would replace it unless you check ethernet cables with good tester
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
07:43 AM
2012-08-30
07:43 AM
Ethernet cable is good and fine , i've tested it using a PC and it works
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
08:05 AM
2012-08-30
08:05 AM
Contact support
Also test with different switch to duplicate and contact support
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-30
08:13 AM
2012-08-30
08:13 AM
Already done on 2 different switch with the same result, tahnks for your help i will contact the support
Message 16 of 16
