×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
WFS709TP: Setup for multiple locations/subnets
abrick1
Follower
I am attempting to setup our WFS709TP AP controller to run WGL102 APs that are located at various locations (and in different subnets) across our WAN environment.
I not having much luck with any of the official manuals - they are vague at best when describing how this may be done.
Is it possible for APs in different subnets and locations all use the same SSID? I assume that these must be setup to use different VLANs but I am getting some non-descript errors when attempting this. Using a different SSID is accepted however it would nice if I could use the same SSID given it would minimise client setup for those people that move across locations/subnets and allow them to us just the one preferred network.
If anyone can give me a more in depth description (than the manual provides) as to how this may be achieved (hopefully with an example with IPs) it would be greatly appreciated.
Message 1 of 4
jmizoguchi
Virtuoso
Re: WFS709TP: Setup for multiple locations/subnets
just give you some heads up.. very little uses this models so you may not see much reply...
I have never played with it so I'm out loop on this..
jchri9 or beisser might have some info ....
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
REGGRUNDY
Novice
Did anyone ever get any answers around this?
Message 3 of 4
jame_s
this may be too late for you, but i got this working
i used the local dhcp server in the remote offices to serve up the bootp options and it seemed to work ok
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4812 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
