Reply
WIFI EXTENDER
PaulTolman
Follower
WIFI EXTENDER
I have a NETGEAR R7000 Router I just purchased NETGEAR AC1900 Extender. I've setup using NETGEAR APP. I have 2 WiFi networks 2.4 & 5G how can I tell if the router & extender are using the same network ?
Message 1 of 2
Guru
Re: WIFI EXTENDER
What extender did you buy? AC1900 is a speed.
What firmware is on it?
Have you logged into the extenders settings and checked its connections?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 98 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
