- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WIFI Extenders
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
which extenders? a model helps?
And how do you have them setup?
I would highly recommend against daisy chaning them.
Daisy chain: router---->extender------>extender
star would be prefered.
star: extender<-------router------>router
i usually recommend to people if they're needing more than 1 extender to move to a full mesh system like orbi versus trying to juggle mutliple extenders.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
Thank you for the feedback. I have a 6150 and a 6120. I set them up using the WPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
Are you having issues setting them up? and if so, what are the issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
No, my issue is that the 6150 seemed to fall offline about once a week. It is about 4 yeas old so I purchsed teh 6120 to use as a backup. I have them both plugged in. My Ring cameras are linked to them and they often just stop working. I unplug the extender and plug it back and that usually fixes the issue. Now that is not even working. The extenders link to my phone but then when I try to access the internet, it wont.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
What router is it connected to?
When 2 devices are failing in the same route, it points to something else being the issue. The router is the backbone of the system and if its lease is expiring, it could be causing the issue.
Did you set them up using wps?
If so, try factory resetting and reinstalling using the installation assistant. don't use wps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI Extenders
The router was just replaced by Xfinity last week. They worked for a few days and then the problem started. I will try using the install asst.
Thank you.
