× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WIFI externder not working properly
somank
Follower
I've been using this extender for last 2 months. Now it's having connectivity issues. It doesn't connect to my wifi router although able to connect to other devices. It was working fine but out of nowhere it started having wifi connectivity problems.
I've tried wps button, manual setup, factory setups. But nothing works.
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: WIFI externder not working properly
Hello somank
I would try to do a factory reset by holding down the reset button for 10 seconds and then do the setup again you also may want to change the wireless channel on the router.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2137 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
