- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN1000RP does not work2 - only yellow light
- Mark as New
- Bookmark
- Subscribe
- Permalink
My WN1000RP extender has stopped working after I change a config in its application and apply. When I tried to access again, it just turns on the yellow light, does not go green and does not appear on the network. Even trying to reset the factory does not work, it does not turn on anymore. What if there is no other way to access it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN1000RP does not work2 - only yellow light
Some questions.
Which led is yellow? there's 3 led's.
If you successfully reset the device (try holding reset again for 7-10 seconds), it won't automatically reconnect to the network. If you pull up a wifi scanner, can you see it broadcasting?
You'll need to fully redo your setup. Refer to the install guide to do so.
here's the support page for your device. It'll have manual, install guide, firmware, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried resetting it several times and nothing happens. The yellow button is the middle button, status led. And it does not show up on wireless networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's what I'd try.
1. move it to a different outlet.
2. hold the reset for 30 seconds while plugged in
3. unplug while still holding reset, hold for 30 seconds
4. plug it back in, all while holding reset for another 30 seconds.
5. Let it boot. give it 1-2 minutes.
what are the leds doing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried this and the yellow led did not even blink.
It stays always turned on and does not change ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
something might have gotten corrupted during the changes/resets. Looks like this model is quite a bit older so I doubt its within warranty (?) Plus it doesn't have an ethernet port to force new firmware to it via a tftp procedure.
It might be time to call it and upgrade/update. Sorry I wasn't more help.
