- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN2000RPT - CAN´T CONNECT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I can´t connect my WN2000 RPT to configurate. I tried to restore factory settings but doesn´t work and it´s only flashing the second light. When I connect throught ethernet cable there is not connection and with wifi connection I can´t see the _EXT network.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN2000RPT - CAN´T CONNECT
Hi Chema_68,
Is this your first time setting up the WN2000RPT?
Please try placing the WN2000RPT next to your router when you setup. Which router is connected to the WN2000RPT?
Do you have another ethernet cable available to test with your WN2000RPT and computer?
When you tried the factory reset, did you press the factory reset button until the Status LED starts blinking?
