- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN2000RPT EXT
- Mark as New
- Bookmark
- Subscribe
- Permalink
WN2000RPT EXT
Hello, after several attempts to update the firmware and reset behind the equipment, I still have a single light flashing in front of the equipment.
try to update the firmware with tftp to the latest version available on the site and nothing, the extender starts up and then remains the same with the green light flashing.
Does anyone know what I can do to revive the extender?
Or do I have to use it as a paperweight?
Thank you.
Hola despues de varios intentos de actualizar el firmware y de reset por detras del equipo, sigo teniendo una sola luz ver parpadeando por delante del equipo.
trate de actualizar el firmware con tftp a la ultima version disponible en el sitio y nada, se inicia el extener y luego queda igual con la luz verde parpadeante.
alguien sabe que puedo hacer para revivir el extender?
o me toca usarlo como pisapapeles?
gracias.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN2000RPT EXT
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
