× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WN2000RPT Link Rate only 54mbps
HeroicGlaedr
Hi guys,
I am having problems playing large media files (HD) on my WDTVLive Device from my server so I bought myself a WN2000RPT Repeater to extend the signal.
I got it up and running fairly fast but am totally puzzled that it only connects to the WNR3500v2 router at 54 Mbps link rate, although it complies with the n-standard. I can place the repeater next to the router and it doesn't pick up any higher rate.
Afaik a repeater halfs the datarate, which, at best, should be around about 150Mbps, depending on where I put the repeater.
It may have something to do with the encryption mode that it forces the repeater to use a lower wifi-standard. I have set WPA-PSK [TKIP] + WPA2-PSK [AES] on my router and it is the same on the repeater.
Atm I cannot find any solution to my problem and am glad for any help to increase the link rate.
Cheers
Message 1 of 4
jmizoguchi
Virtuoso
Re: WN2000RPT Link Rate only 54mbps
Use WPA2 only and see
Message 2 of 4
HeroicGlaedr
Hi,
Thanks for your reply. I set the encryption to WPA2 on both the router and the repeater and it now has a higher link rate.
The problem is that I need it to work with WPA2 + WPA because I've got devices which cannot use WPA2..
Message 3 of 4
jmizoguchi
Virtuoso
WPA limits 54Mbps so looks like with WPA+WPA2 is making WPA for extender
There is much you can unless you do WPA2
Message 4 of 4
Discussion stats
  • 3 replies
  • 5945 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
