Shung
Dec 26, 2014Aspirant
WN2000RPT - V3 - Can't open hidden dhcp server page- why ?
good evening gents,
I own a wn2000rpt V1, that I use to bridge the signal from my 4G hotspot. it means that I can activate the dhcp server on the WN2000RPT to connect more than 5 wifi device to the internet (my 4 hotspot dhcp is limited to 5) and that I can also connect computers to the internet via a physical network (rj45)
everything works fine, and I was able to enable the dhcp server on the wn2000rpt v1 with a proper IP range, which means that I would lose the wifi connection..
Anyway, I wanted to reproduce the exact same thing at one of my relatives.
Same 4G Hotspot. I bought another wn2000rpt, and this time it came as a V3
I did configure everything and it works, except that I am unable to open the hidden dhcp server page to set it up.
after logging in the http://www.mywifiext.net/ page, I can access all my setting etc..
but when I type this http://www.mywifiext.net/cgi-bin/hidden_dhcpd.html to access the hidden page, chrome tells me that the site/page cannot be found.
Internet explorer tells me the page does not exist.
Anyone know why this is happening. I remember that the first day I set my own wn2000rpt (v1) it would do the same, and then it worked the second day... but i dont know or remember what changed exactly.
Do you know what could be a reason for the http://www.mywifiext.net/cgi-bin/hidden_dhcpd.html page not to show up, when the http://www.mywifiext.net/ setting page comes up fine and that I can log in ?
Your help is greatly appreciated. Thanks a lot !
ps:im in switzerland, if that makes any difference
- totatooAspirantHmmmm! I am waiting to hear the answer.
- ShungAspirantno answer ???
I really need help.
there has been a storm here, and it has fried my old wn200rpt V1..
I have bought a new V3 like for my relative, and I am unable to access the hidden DHCP page on this one either....
PLEASE HELP ! I absolutely need to activate the DHCP
