× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN2000RPT and MAC filtering address
Xiscu
I have a WN2000RPT working like as range extender, working with my router, which has enabled mac address filtering.
The pc `s connected to WN2000RPT, have wifi access, although their mac address are not on the list.
That is, MAC filtering only works when the computer it's connected directly to the main router.
Is not possible to filter the mac adress through the WN2000RPT?
Thanks in advance.
Message 1 of 4
jmizoguchi
Virtuoso
Re: WN2000RPT and MAC filtering address
Using extender, all the devices are under extender's Mac address I believe ..
Message 2 of 4
Xiscu
Thanks for the help.
That is what it seems, but it's unsafe for the wireless network.......
Message 3 of 4
jmizoguchi
Virtuoso
Mac filter should be counted for security. Easily spoof so strong encryption would sufficient such as wpa2
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3483 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
