× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN2000RPT and Xbox live
mikeswim07
Follower
Hi,
I recently purchased a Netgear Universal WiFi Range extender. I set it up and it seems to work fine for connecting to the internet. But, I am unable to connect to xbox live through the wireless connection produced from this extender. I know the problem is with the extender because the weak internet connection from my Motorola router can connect to xbox live fine.
When I diagnose the internet connection on my xbox, it says there is a DNS error occurring.
What can I do?
Message 1 of 3
mdwright1032
Re: WN2000RPT and Xbox live
I would try to do a hard reset on both the router and the extender.
There should be a little pin hole on your router and on your extender you can stick a toothpick in. Put it in each for 10 secs and see if that helps.
Message 2 of 3
reisendegringo
I'm having the same problem, my son's XBox cannot connect to XBox Live when hardwired to the range extender. I can, however, connect to the net wirelessly via the extender using a PC, idevice, and Kindle. If, however, I try to use an ethernet cable, and a PC, I end up with a password prompt and the admin page of the extender. I suspect that the XBox is receiving the same request.
I ended up buying an XBox wireless adapter, (which took some doing as none of the stores here in Norway carry accessories for earlier XBox 360 models without built-in wifi).
Message 3 of 3
Discussion stats
  • 2 replies
  • 10988 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
