× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN2000RPT cannot update firmware
czim
Novice
To connect to the nex Freebox, I was told by the support to update the firmware.
I downloaded the firmware, but cannot find where to clic on the Netgear interface to do the update.
Ther should be a maintenance/ update clic
When I connect to the Repeater (mywifiext), it allways starts the wizard
Message 1 of 2
jmizoguchi
Virtuoso
Re: WN2000RPT cannot update firmware
Make sure you have setup your extender before you try to upgrade the device
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 7201 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
