Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN2000RPT creates second SSID
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-14
06:24 PM
2011-10-14
06:24 PM
Hi,
I just bought a WN2000RPT
and I'm really annoyed about this device.
Actually ist "works" but unfortunatly not in the way I supposed it to.
I bought a repeater to extend my existing WLAN and not to create a new one!
The description of the device is really misleading.
If I had known how it really works I would have rather bought a second router instead of the repeater.
This would have had exactly the same effect.
It would only be much more reliable and fast, because it would be possible to use a wired connection between the two routers (wires are already existing!).
Has anyone an Idea, how to deal with this problem?
If not, the device will be returned to the sender in a few days....
Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-14
06:38 PM
2011-10-14
06:38 PM
Re: WN2000RPT creates second SSID
I would bought access point in the first place and think about doing repeating or using extender if you have ethernet cable. Bought wn2000rpt to bottleneck your wireless for 2nd SSID. half the performance so throughput will be not good
extender should connect existing and setup 2nd SSID SSID ... xxxx_ext in such
try different SSID name then first.
usually no one complaints about SSID on this model. it's usually more about can not make extender to connect existing network .
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-15
05:42 AM
2011-10-15
05:42 AM
Sorry, I didn't really get your point.
jmizoguchi wrote: I would bought access point in the first place and think about doing repeating or using extender if you have ethernet cable.
Of course an access point is already existing. The cabels are just for the Desktop-PCs and and the access point (plus the repeater) is for Notebooks and other mobile devices.
The point is, I want to be able to take my Notebook or Smartphone and walk from one End of the building to the other End without having to disconnect from the router and reconnect to the repeater. 😉
jmizoguchi wrote: extender should connect existing and setup 2nd SSID SSID ... xxxx_ext in such
Thats true! The first connection isn't really that easy.
It took me half an hour to connect. But finally after updating the firmware I managed it. 🙂
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-15
05:46 AM
2011-10-15
05:46 AM
if you got ethernet cable, get small switch, and AP..
done deal.. not brainer
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-16
05:17 AM
2011-10-16
05:17 AM
Yes, of course that would work.
But then I would also have two SSIDs because I need two APs, as the buildung is to big and one alone isn't able to cover it.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-16
07:42 AM
2011-10-16
07:42 AM
You can same SSID or different SSID not sue your point. My point is if you have CAT5 at remote end, put switch and AP. Using same SSID or different SSID is your choice
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-16
08:25 AM
2011-10-16
08:25 AM
Ah ok.
jmizoguchi wrote: My point is if you have CAT5 at remote end, put switch and AP. Using same SSID or different SSID is your choice
Setting up a second AP with the same SSID is no problem?
I thought this would result in a conflict (thats why i bought the repeater instead).
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-16
09:56 AM
2011-10-16
09:56 AM
Same SSID, same channel , same encryption
Or
Differrent SSID. Different channel
If both AP will not overlap the coverage, might as well use different SSID but that your options
Or
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-16
10:46 AM
2011-10-16
10:46 AM
Try this
Same SSID
One AP on channel and one on channel11
Same SSID
Message 9 of 9
Announcements
