× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN2000RPT no wireless light
amber815
Follower
Yesterday all of a sudden the wireless light (the top one) went out. I tried resetting the device and I can not get access to mywifiext.net to reconfigure the device to my network. I have also tried connecting directly with an ethernet cable and that did not work as well. If it matters I am working on a Mac just in case there are different instructions.
Any help would be greatly appreciated.
Thanks!
Message 1 of 2
jmizoguchi
Virtuoso
Re: WN2000RPT no wireless light
top is power isn't it? if so either power supply or router died.
if the unit is still under warranty then call support or use my.netgear.com ask support
Message 2 of 2
Discussion stats
  • 1 reply
  • 4461 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
