× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000 cannot connect
kris245
Follower
My WN3000 wifi extender cannot connect to my wifi. Even though I have gone through the setup process several times, the wifi extender show up with my network name and the _EXT at the end. No matter what I do it cannot connect and the wifi lamp newer lights up.
I use windows 10.
The wifi extender was located directly next to the router.
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 3
Guru
Re: WN3000 cannot connect
Did you try
  • resetting the extender
  • connecting a client to the NETGEAR_EXT network
  • browse to www.mywifiext.net
  • set up the extender from the web ui
Don't press the WPS button.
Message 2 of 3
Zack_Porter
Same issue here w AC1200 EX6150 v2
Worked fine for 4 months. Now will "not connect to Internet".
I have followed EVERY recommendation at Netgear online.
My router can see the extender. It shows 2 green lights on lower right front.
Will not connect to Internet.
Tech Support tried to extort money from me due to "after 90-days free warranty period." Are you kidding?
How do I get Internet connection back to this device?
Thank you.
Model: EX6150|AC1200 WiFi Range Extender
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 953 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
