× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
WN3000 remains connected to an old network
matteo84
Tutor
Hello everyone,
I bought a WN3000 some months ago and I used successfully til now with my network (Alice-000000 --> Alice-000000_EXT).
Now I changed my internet provider and I have a new network (Telecom-000000) and I would like to extend it (Telecom-000000_EXT).
Instead, if i try to install WN3000, my computer recognizes the old obsolete network: Alice-000000_EXT.
I resetted the extender, but the problem remains.
How can I do to make the extender connect to my new network?
Thank you in advance
Message 1 of 7
storm1985
Prodigy
Re: WN3000 remains connected to an old network
@matteo84 Follow these steps:
1. Connect to Alice-000000_EXT.
2. Access mywifiext.net.
3. Under Setup click on Connect to Existing Network.
4. Select the new SSID = Telecom-000000.
5. Change your existing SSID = Alice-000000_EXT to Telecom-000000_EXT. You can use the same password if you want.
6. Once changed go to your computer's WiFi connections and connect to Telecom-000000_EXT.
Message 2 of 7
matteo84
Tutor
@storm1985 thanks for your reply, but I fail to connect to Alice, even if I see it in my wi-fi networks list..
Message 3 of 7
storm1985
Prodigy
Reset the extender and connect to the default SSID.
Message 4 of 7
matteo84
Tutor
Hello
basically I should delete the old connection so 'that I look for the new ... how can I do? thank you
Message 5 of 7
storm1985
Prodigy
Push the reset button for 10seconds. Power light responds when you push it.
The extender SSID should be back to NETGEAR_EXT which is an unsecured network.
Once connected wirelessly to that network, open a browser which redirects you to mywifiext.net.
Go through the setup wizard and reconnect your extender to the new SSID of your router.
You can also check the Installation guide.
Message 6 of 7
matteo84
Tutor
Hello
I solved it, thanks very much for the help.
Spoiler
Message 7 of 7
Discussion stats
  • 6 replies
  • 3951 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
