- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN30000RP
- Mark as New
- Bookmark
- Subscribe
- Permalink
WN30000RP
My range extender has worked fine for 9 months but today, the client link light has turned red. Coincidentally we are having problems activation our Sonos Pay 3 via our IPhone 5 (which has also been working fine until now). I have tried moving the extender to other rooms, including where the main router is , but the client link light remains red. Any ideas appreciated. Thanks. Les
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN30000RP
Hi leslawson,
Which router are you using?
Please also confirm which version of WN3000RP you are using.
http://support.netgear.com/product/WN3000RPv3
http://support.netgear.com/product/WN3000RPv2
Are both WN3000RP and router updated to latest firmware?
Try changing the WiFi channel on your router, you may be experiencing interference from neighboring networks:
http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-chang...
Also try resetting the WN3000RP to factory defaults:
(This process erases any settings that you configured in the extender.)
Insert a paper clip into th eFactory Reset hole and hold it until the Power LED blinks amber.
Release the button.
All the LEDs turn off for about three seconds.
The Power LED lights solid amber for about 30 seconds.
The Power LEDlights solid green.The extender returns to its factory settings.
