× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RP Help.
uadmirin
Novice
WN3000RP Help.
I hooked up the extender this morning and it is working perfectly except for one computer. I am getting 5 bars on two laptops and a good signal on a ps3. However, I have one more laptop that will not connect to the network.
It is running Vista. I select the extender to connect to which is at 5 bars. It says connecting then it will ask for my pass phrase. I enter my pass phrase then it says it cannot connect to the extender.
I keep getting the same error message. Not sure what to do. Thanks for the help!
Message 1 of 2
jmizoguchi
Virtuoso
Re: WN3000RP Help.
Adjust the encryption you choose to use with extender
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6682 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
