Bluepassion's avatar
Bluepassion
WN3000RP having problems setting up
Hi I'm having trouble setting the wn3000rp up.
So here goes I bought a new router TP link 450 Mbps hoping it reach into the garden but I Does not so I bought the netgear extender this is where the trouble starts,when I connect using WPS my router name disappears and I then get two netgear names one with ext but the trouble is it asks for a password to connect to the network and its not the one I've set.
I really need some help with this as it driving me nutts
  • Use encryption to connect to the main wireless (ex WPA2 not WPS method)
    Follow the manual for that.
    you can download at support.netgear.com
  • I tried that too the problem was I could not connect to the page to get started
  • all sorted now with help of the support lady called Marie :)now got 2 bars strength in the garden
