×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
WN3000RP replace antenna
pdneri
Follower
Is it possible to remove the receiving antenna (the one connected to the router) and replace it with a cable and a new antenna (or keep the original one)?
I need to put one of the 2 antennas ouside the window
Message 1 of 2
Givanny
Re: WN3000RP replace antenna
Como puedo colocar otra compañìa de cable que estoy utilizando ya que cambie la anterior
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3715 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
