× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WN3000RP - so close but no cigar
EmilG
Novice
I can't quite get this thing working, I get "can't connect to the internet".
Here's my setup:
Router WNDR3400
Router -> wireless -> PC
Router -> wireless -> WN3000RP -> wireless -> iPad
Via the PC I can look at the router and see the mac addy of the WN3000RP on it's connected to page.
Via the PC I can also access the WN3000RP and see the mac addy of the iPad on it's connected to page.
The iPad shows connected but can't get to the internet.
The iPad also won't connect to the WN3000RP via www.mywifiext.net.
Any ideas?
Thanks!
Message 1 of 30
EmilG
Novice
Re: WN3000RP - so close but no cigar
I have mac address filtering turned off on the router for now.
Message 2 of 30
jmizoguchi
Virtuoso
try using public DNS on iPad and see
Message 3 of 30
EmilG
Novice
No luck, tried google 8.8.8.4 and 8.8.4.4.
I even tried the my.google.com addy 209.191.108.146.
I'm thinking it's something in the router blocking it but can't figure out what else.
Guess I need to start disabling stuff till it works then figure out how to make it right.
Message 4 of 30
jmizoguchi
Virtuoso
are you using WPA2 encryption on main router?
Message 5 of 30
EmilG
Novice
Yes i am..........
Message 6 of 30
EmilG
Novice
I even turned on DMZ on the addy the extender is on 10.0.0.5, as I understand it should let everything through.
I'm starting to think it's in the extender.
Message 7 of 30
jmizoguchi
Virtuoso
DMZ will do nothing in this case for extender
Message 8 of 30
EmilG
Novice
Thanks, I realized that when the router changed the extender address to 10.0.0.6.
Message 9 of 30
jmizoguchi
Virtuoso
extender should remain the same as our primary LAN subnet
Message 10 of 30
EmilG
Novice
If I understand correctly I have IP addresses 10.0.0.2 to 10.0.0.15 allocated for use. The extender is on 10.0.0.5.
Thanks for helping a networking newbe.
Message 11 of 30
jmizoguchi
Virtuoso
that looks perfectly ok... you explained early bit different.
Message 12 of 30
EmilG
Novice
Newbe talking,sorry.
On the status, statistics screen WLAN looks correct but LAN shows Link Down if this helps.
Done for tonight, 4:30am rise time for me.
Thanks again!
Message 13 of 30
jmizoguchi
Virtuoso
link down with device hooked up to the WN3000RP lan ports?
Message 14 of 30
EmilG
Novice
I don't know the difference between WLAN and LAN.
I was talking to the extender via the router link. (Pc->router->extender)
On this latest attempt I'm unable to access the extender directly via the iPad through www.mywifiext.net although the signal shows up strong.
In previous attempts I remember I was able to link via mywifiext but not now.
Maybe another factory reset is in order and try again?
BTW I also tried installing via the wired link.
Thanks
Message 15 of 30
jmizoguchi
Virtuoso
WLAN- WIRELESS
LAN - commonly connected with ethernet cable.
Message 16 of 30
EmilG
Novice
jmizoguchi wrote:
WLAN- WIRELESS
Ok, since I was linked via wireless on both sides (router->extender and extender->iPad) that's why LAN showed link down, got it!
I'll try factory reset tonight (or maybe tomorrow night) and go through it again. I'll first try the simple WPA method others have had no problems with (although I tried it before that way before). If no luck I'll do manual with a wired link to a pc.
Thanks
Message 17 of 30
EmilG
Novice
Got it working!!!
Seems that manually entering the IP info did it even though it was still at the same local IP. There is obviously more going on internally that we know but it works, that's all that matters.
Thanks for your patience, knowledge and time, I really appreciate it!
Message 18 of 30
jmizoguchi
Virtuoso
Awesome.... enjoy the new device:)
Message 19 of 30
EmilG
Novice
Thanks!
Nice strong signal, great latency too.
Message 20 of 30
sataponw
Hi sorry for bringing this thread up again.
I am having a similar issue and I can't seem to solve it.
I am going from my router -> wireless -> 3000rp -> wireless -> laptop
On a very very rare occasion (by pulling the extender from the plug and plug in back in) I would be able to access mywifiext.net for about 5 seconds.
On my laptop, it always show up as unidentified network. I am pretty much stuck.
With a few chance of getting into the extender, I managed (or I think I did) to change to static IP 10.0.0.11 subnet 255.255.255.0 Gateway/DNS 10.0.0.1 (router IP).
I tried changing my laptop IP setting to IP10.0.0.101 (tried 10.0.0.13) subnet 255.255.255.0 Gateway/DNS 10.0.0.1. I still get the same unidentified network.
I did tried with LAN connecting to my laptop, still unidentified network. I also tried this on my other laptop, still the same result.
Hope someone can help me.
Thanks,
Satapon W
Message 21 of 30
EmilG
Novice
Can you access the extender through the router link. via 10.0.0.11?
Message 22 of 30
sataponw
no I can't. It seems like I can access the extender when the windows was identifying the network. Once it changes to "Unidentified Network", I can't access it at all.
I am using Windows 7 (x86 and x64) on both laptops. WPA2-AES, router WNDR3700.
Message 23 of 30
sataponw
update... I tried resetting the extender. I am able to connect to the extender during the original process (ie. not setup to connect to my router yet).
I can manually connect the extender to my router (without going to the smart wizard), and still get access to the extender. However, the IP of the extender doesn't seem to change (still 192.168.1.250 and Gateway/DNS 0.0.0.0) hence not getting the internet.
Once I change the extender IP address to 10.0.0.11/255.255.255.0/10.0.0.1, it becomes "unidentified network" again.
I tried changing the gateway/dns to 192.168.0.1 (my internet provider's router IP) and still doesn't work.
I don't know what to do now.
Please help
Message 24 of 30
jmizoguchi
Virtuoso
192.x.x is not internet routable IP so that is LAN subnet for private.
Message 25 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 17484 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
