× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RP speed rate?
anekin007
Follower
My Current setup is a Netgear WNDR4000 for the main router and the WN3000RP as the extender. I have everything setup and working but my issue is speed. When connected directly to my main router within good range my internet speeds are 55mbps/10mbps. When connected to the WN3000RP my speed is 25mbps/10mbps. I notice when logged into the setting of the extender the link speed is 130 and wireless mode is 145mbps. With the WNDR4000 I can change the wireless mode speed to like 145mbps and 300mbps. I have it set at 300mbps. Since the extender is rated for 300mbps is there to change mode to 300mbps?
Message 1 of 3
marcelolopezjr
Re: WN3000RP speed rate?
Has ANYONE gotten an answer to this query?
Message 2 of 3
netwrks
Master
You should see around around a 50% loss in wireless throughput, connected to an extender.
EDIT: SmallNetBuilder test results WN3000RP. The best way to extend a wireless network is purchasing a router that has Access Point mode, ethernet connected back to your Base router.
Message 3 of 3
Discussion stats
  • 2 replies
  • 9682 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
