× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RP won't connect to internet
Fitter1
Follower
I just bought a R7800 WIFI Router. Followed all the setups, connected WN3000RP extender. R7800 will access the internet, WN3000RP will not. Both show up as on my network. Factory reset the extender and reinstalled. Still will not connect to internet. Could use some help.
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: WN3000RP won't connect to internet
Hello Fitter1
Try changing the wireless channel on the router and make sure you are using WPA2 security.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2761 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
