× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RPv3 Can I wirelessly connect this extender to a Google Mesh System
ericjs54
Follower
The Google Mesh access points don't have an ethernet connection. I would like to connect the Netgear extender wirelessly to the mesh system so I can run an ethernet cable from the extender to a music server. Can this be done? If so, how? Can't find any help online.
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 2
olympos1625
NETGEAR Employee Retired
Re: WN3000RPv3 Can I wirelessly connect this extender to a Google Mesh System
Hi ericjs54,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for not being able to get back to you immediately. You may use the Netgear extender to connect to your existing Google Mesh system. A similar setup process should be applied. You may check the links below:
https://kb.netgear.com/23517/How-do-I-set-up-my-NETGEAR-WiFi-range-extender
https://support.google.com/googlenest/answer/7139494?hl=en
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
