× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RPv3 - Name for extended WIFI network
TonySp
Follower
I have gone through the process of setting up my wifi range extender and am at the final stage of entering the name of my extended WIFI network. However, when I enter the name and click 'Continue' nothing happens and I cannot progress to the next screen. Is there a reason for this, such as a specific naming convention for the network?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 2
Guru
Re: WN3000RPv3 - Name for extended WIFI network
I think it is seeing a syntax problem but isn't telling you.
If there are other entries on the screen, then check them all.  Is there something unusual about your network name?  Spaces or unusual punctuation?
Message 2 of 2
Discussion stats
  • 1 reply
  • 445 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
