× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WN3000RPv3 connection issues
J_O_S_H
Follower
I ran through the connection instructions and all went well but now that it indicates that it is connected when I select EXT Network it doesn't accept the password to join the network and its the same as the network that its extending. Any ideas?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: WN3000RPv3 connection issues
Hello Josh
It should be the same password as the main router but sometimes you will have to go back into the settings and change the password. To do this connect to the router or the extender and go to www.mywifiext.net and then use admin/password to login and change the password.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1220 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
