- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN3000RPv3 firmware 1.0.2.24 has less settings than 1.0.1.24?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I just bought a WN3000RPv3, it came with firmware version 1.0.1.24. Once I verified everything was up and running I upgraded to the latest firmware version, 1.0.2.24. It looks like the admin interface is much more modern, but it also looks like I lost the ability to configure a few things, for example the Wifi speed seems to be locked to 144Mbits, while with the previous version I could bump it to 300. It also looks like it's locked to channel 1, is this normal or did the system pick it up as the best channel?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN3000RPv3 firmware 1.0.2.24 has less settings than 1.0.1.24?
Did you factory reset the router after the firmware upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, why would I factory reset it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems from your initial post that there have been significant GUI changes in the new firmware, and in that case given the issue you are having a factory reset can resolve that kind of problem. You could save your current configuration first if you have doubts that a factory reset will help, then reload those settings after the reset (after checking that the issue is fixed or not).
