- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN3000RPv3 loss of IP address
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am using three WN3000RPv3 WiFi Extenders as Access Points connected to sockets in different rooms with Ethernet cables. Each Extender is configured with an unique SSID, and IP address I use DHCP.
My router is using 172.17.12.x addresses and when I connect to my Extender with my smartphone I got an IP address in that range.
But sometimes, I don't understand why, connection on my smartphone stops and IP address on it changes to 192.168.10.y.
Trouble started since I have added the third Extender in another room.
I wonder if the problem is not coming from router which provides IP addesses to all Extenders, or if there is a limitation of Extender number plugged on the same Ethernet network ?!?
Thanks for your help 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN3000RPv3 loss of IP address
Hello Abdel,
You can try setting up IP address reservations on your extenders to keep the IP's stable
~Christian
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
