× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WN3000RPv3 will not connect to Verizon Hotspot
berryp1
Follower
I have a cable coming in from my Photovoltaic System.  It plugs into the extender.  I am trying to connect the extender wirelessly to my Verizon 4GLTE Hotspot.  While the two lights on the side, and the light on the top right, function properly, I am unable to successfully activate the light on the left.   The Hotspot recognizes the Extender, but will not connect, even after several resets with a pin on the bottom.  Frustrated.
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: WN3000RPv3 will not connect to Verizon Hotspot
Hello berryp1
Have you made sure the Hotspot is using WPA2 security and make sure you add the MAC address of the extender to the hotspot Mac filtering list.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3069 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
