× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WN3000RPv3 won't connect to new router
logan0504
We got a new 5G router and the WN3000RPv3 extender won't connect to it.  I have tried to factory reset multiple times.  I have tried the WPS connection method.  On the mywifiext.net website, it says that "your extender is not connected", so I can't continue using that method.  I am at a lost! Any ideas?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 4
Guru
Re: WN3000RPv3 won't connect to new router
Are you connected to the extender's wifi network when you go to mywifiext.net?  Or are you connected to your new router's network?
Message 2 of 4
logan0504
The extender network does not show up as an option so I am on my new router's network.
Message 3 of 4
Guru
Then you can't use mywifiext.net to browse to the extender web page. You either need to connect to the extender's ethernet or it's wifi network to do that.
Try looking in your router's attached device list for the extender - if you see it there you could try browsing to the ip address.
Otherwise, you'll need to do a factory reset on the extender.  The procedure is in the manual I linked above.
Message 4 of 4
Discussion stats
  • 3 replies
  • 2173 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
