- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WN3000RPv3
- Mark as New
- Bookmark
- Subscribe
- Permalink
My WN3000RPv3 is not seeing (through mywifiext console) any wi-fi network (SSID) packed inside Netgear R6120-100INS AC1200 Dual-Band Wi-Fi Router. Is this because of any known compatibility issue?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you mark the answer as solved it gives those with the same problem the fix.
Glad it fixed the problem for you!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN3000RPv3
Not sure what you mean by "packed inside". Basically when you're setting up your extender, it can't see the R6120's signal?
What firmware is on the extender? Update if not current.
Firmware on the R6120?
Are you trying to do the setup using WPS or through the browser gui?
What browser are you using? Occassionally this does have an impact. You can try a different browser.
Here's what I'd try if it was me.
1. Reset the extender. Hold reset for 7-10 seconds.
2. In the R6120, set the wireless channel to 1-6-11 if its on auto. you can do a wireless scan to see which channel has the least interference.
3. for the initial setup, have the extender in the same room but not right next to the router. After setup, minimum distance is 30 ft.
Try these and let us know what happens as well as the responses to the questions. Here's the support page for your extender and R6120
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WN3000RPv3
In the R6120 setting the wireless channel to 11 from auto resolved my issue. Rest (e.g. firmware) were in agreement with your recommendation. I was using browser GUI for setting things up.
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
