× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
WN3100RP error disabling SSID broadcasting
log-out
Hi all, I've recently purchased a WN3100RP and it works fine.. I want to disabling SSID broadcasting, but then I can't connect to it with my laptop (win 8.1). If I activate SSID broadcasting, I connect without any problem. This problem is only with the laptop, I can connect it with my phone and tablet. Any ideas to fix it?
Message 1 of 4
nhann
NETGEAR Employee Retired
Re: WN3100RP error disabling SSID broadcasting
Hi log-out,
In order to connect to a disabled SSID, you will need to manually create a network profile. Listed below are instructions from http://kb.netgear.com/app/answers/detail/a_id/22144
1. On the Desktop screen, right-click the Wireless Icon located on the lower right hand corner of the screen, and select Open Network and Sharing Center
2. Select on Set up a new connection or network and then click on Next
3. Select on Manually connect to a wireless network and then click on Next
4. Manually enter the required credentials for the wireless network you are trying to add, then click on Next
5. You will get a confirmation that the profile is successfully added
Let us know if you need further assistance.
NhanN
Message 2 of 4
log-out
Hi nhann,
I've created manually the profile, but my laptop says that it can't connect the the network. If I enable againt the SSID broadcasting, it connects successfully.
Message 3 of 4
Babylon5
There are some client devices and operating systems which don’t work well with disabled SSID beacons.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3316 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
