Orbi WiFi 7 RBE973
Reply
WN3500RP- Super slow speeds
Nickf99
I use the WN3500RP to game on my xbox one and whenever I run speed tests on the system it says my download speed is about 1mb or 2mb, but never dips above. Any tips/help would be much appreciated!
Message 1 of 10
Nickf99
Re: WN3500RP- Super slow speeds
Also, I have the Comcast Blast wifi plan, which is 105mbps. So with the extender I should atleast be getting 20mbps.
Message 2 of 10
Fairytail
Virtuoso
Connect a device wired to the extender and check the speed. Also try moving the extender closer to the router.
Message 3 of 10
Nickf99
I have connected the system with an Ethernet cord to check the speed and I get the same speed. I have not however moved the extender closer to the router.
Message 4 of 10
Fairytail
Virtuoso
Can you check the link rate you are getting on the extender's UI?
Message 5 of 10
Nickf99
I'm getting 105mbps link rate for the extender. Where is all this bandwidth going?
Message 6 of 10
Nickf99
I'm thinking I may just invest in a powerline adapter and plug that directly into my router because I cannot figure this out.
Message 7 of 10
Fairytail
Virtuoso
Check the firmware of the extender. It may need an update.
Message 8 of 10
Nickf99
Firmware is up to date, on both the extender and the router.
Message 9 of 10
nhann
NETGEAR Employee Retired
Hi Nickf99,
Please try changing your WiFi Channel as you may be experiencing interference from neighboring networks.
http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-chang...
Let us know how it works for you.
NhanN
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 6436 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
