Carrot_Cruncher's avatar
Oct 16, 2012
WN802T-200 Channel / Frequency = Auto
hi. can anyone explain to me what the Channel / Frequency = Auto option actually does. according to the documentation :
"select the Auto channel option for the AP to intelligently pick the channel with least interference."
however, this is what i was using and was experiencing the link speed dropping out every so often. having done some monitoring it would appear to be caused by a neighbour turning on a wireless device every so often that is using the same frequency (2.142Ghz). having changed my access point to use another channel i'm not getting the same problem. so, as there was only one other device in the area, why was my access point "intelligently" choosing to use exactly the same frequency out of all the options available ? i had assumed the access point continuously monitors the air waves and change frequency when necessary, or does it only do this during the initial boot ? cheers.
  • yeah, i had changed it to channel 11 (one of the non overlapping channels). i live in a rural area and this is the only other wireless device i've ever seen when scanning. i had assumed that using "auto" would do this for me when it noticed something else clashing.
