×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
WNCE2001 bricked after updating firmware v1.0.0.15_1.0.1
ccd1006
I updated my firware to v1.0.0.15_1.0.1 and now the router is bricked.  I followed instruction in the readme and updated with cable (vice wireless).
I tried to reset and it did not flash the internet light (as the insturction noted).  The WIFI light did blink a couple of time (any suggestions)?
When I connect cable to from LAN to PC, it does not assign IP. I tried manually assigning IP to 192.168.168.2 and gateway to 192.168.168.1 but no luck connecting to 192.168.168.1.
I did not see the SSID I setup or the NETGEAR15 which would have expected after a reset.  I did see a hidden network and tried the default SSID and PW when asked but no luck.
Any ideas?
Any suggestion on similar device?   Looks like this i no longer carried in the retailers/webshops.
Thanks in advance.
Message 1 of 4
ccd1006
Re: WNCE2001 bricked after updating firmware v1.0.0.15_1.0.1
Sorry, wrong model.
Travel router PR2000 vice WNCE2001
Message 2 of 4
DarrenM
Sr. NETGEAR Moderator
Hello ccd1006
If you believe the device is bricked you can check to see if its still under warranty and contact Netgear support.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
Message 3 of 4
ccd1006
I called netgear and itss out of warranty and they wanted $s to help fix.  So, looks like I am going to get another one.  Too bad as netgear no longer makes and I did like its functions / versatility.  Thanks.....
Message 4 of 4
Discussion stats
  • 3 replies
  • 2283 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
