× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNR1000v2 Blocking Sites
Couryrr
Novice
I have had this router for a while and have had no issues up to this point. I recently had to do a Factory Reset and updated the firmware to 1.1.2.58. After this it seems that the router is blocking sites and I have nothing configure to do this. Are there firewall rules I am not seeing? I cannot seem to find anything that suggest this. I do not see access to change any setting on this.
:confused::confused:
Message 1 of 2
covillen1
Apprentice
Re: WNR1000v2 Blocking Sites
Hey Couryrr,
What sites are being blocked? post a couple links here. And also are these sites blocked all the time (24/7) or just at certain times? Also what message are you getting when you try to access these blocked sites?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 9707 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
