Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNR3500Lv2 port forwarding issue...
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-27
06:24 AM
2012-12-27
06:24 AM
It's the first time I've posted on one of these customer support forums, but I couldn't get the serial number correct in the live chat registration screen, so here I am.
Both this morning and for the duration of yesterday evening I've been trying to forward port 2302-2305 to the local IP address of 192.168.1.6. That IP is assigned to one of my HP Proliant servers running Windows Server 2008. Yesterday I started a DayZ (video game) server on it and it started running correctly through the LAN. When I forwarded the ports, they just never opened.
I selected the correct device to point it to, set everything to what it normally should be- everything seems fine- but it just won't forward.
Now here's the weirder thing.
Before yesterdays endeavor, I had port 80, 22, and 7777 open just fine. Port 80 and 22 were (and are) going to 192.168.1.2, and 7777 to 192.168.1.3. (Both other HP Proliants)
I then thought the issue could be the Windows Firewall (thought it was turned off) so I tried forwarding port 21 to 192.168.1.2 which is running Ubuntu Minimal with no firewall at all what so ever. That didn't work either.
Then, I un-forwarded port 80 and 22 to see what would happen. It closed the ports just fine, so then I re-forwarded them and they opened again. That's what normally happens of course. Then I closed 7777, tried to reopen it, but it never opened.
I know this is all somewhat confusing, but see the screenshots below as they may help. As of now, 80 and 22 are the only ports that can open, and 2302-5 and 7777 are closed.
I've tried resetting the router and forwarding just 2302 and that didn't work. I tried disabling UPNP and that didn't work either. I even tried unplugging everything and messing up the entire home network and that didn't work.
As you can see, my ISP isn't blocking the ports either: http://customer.comcast.com/help-and-support/internet/list-of-blocked-ports/
And yes, my router is connected directly to my modem, so it's getting the public WAN address.
SCREENSHOTS
SCREENSHOTS
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-27
10:56 AM
2012-12-27
10:56 AM
Re: WNR3500Lv2 port forwarding issue...
WNR3500L is NOT WN3500RP. It is is wireless N router and does not belongs to EXTENDER
Belongs to http://forum1.netgear.com/forumdisplay.php?f=33
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-12-27
11:12 AM
2012-12-27
11:12 AM
Heh... nevermind, solved. The reason the port check tool saw that it was closed was because the server wasn't even running correctly. It was just connecting to nothing :rolleyes:
Message 3 of 3
Announcements
