× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
What do I put where it says "passphrase"??
Tanac99
Follower
Hi, I have the netgear wifi extender model #WN1000RP I recently got a new wifi router and have not been able to reconnect my extender. When I try to set it up with the netgear genie it asks for a passphrase and I'm not sure what I should put there. Please help ASAP!!
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: What do I put where it says "passphrase"??
Hello Tanac99
You will want to put in the password that you used for the new routers wireless and if that does not work you will want to factory reset the wifi extender by holding down the reset button for 10 seconds. You should be able to setup the extender again.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2918 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
