- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What is the best WiFi extender to use with AX5 5 Stream AX4200 Wifi Router (RAX43)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What is the best WiFi extender to use with AX5 5 Stream AX4200 Wifi Router (RAX43)
There is never any "best". It all depends on what is going on at your end, what you need, and how much you want to spend.
You might like to provide a bit more detail and not cram everything into the subject.
This is a good place to start.
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
Try plugging your needs into the filters on the product pages.
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
A better place to ask for help in extenders might be in the section where people talk about extenders.
Extenders, Adapters, & Powerline - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank for your advise. I checked out the link for
but now I am still a bit confused and undecided. The WiFi 6 Extenders that are only dual band or the WiFi 5 Extenders that are Tri Band. The WiFi 6 has the latest technology, but less range. The Wifi 5 have better range but are older tech. The Wifi 5 with Tri Band does sound like the dedicated connection to the router is better, but again the Wifi 5 tech is older and less capable.
Would you have any recommendations based on the router I have?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have any wifi clients that can use WiFi 6?
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V• What is the difference between WiFi 6 and WiFi 7?
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
