- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
When I connect Using Ethernet cord, It only Connects to something called "Network 2"
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, I've been working at this issue for a few hours and tought to find help from people who know more than I do. The problem is that whenever I hook up the extender with a LAN cable, the network that appears is called "Network 2" and not the one that it is set to, however, when I connect via wireless, it appears as the set name. I have no idea what this means in any regard so any information on this is helpful. Sorry for any lack of information or knoledge that I may have, I know absolutely nothing about this sort of thing. Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: When I connect Using Ethernet cord, It only Connects to something called "Network 2"
Are you talking about how windows 10 displays network names?
is it causing an issue?
Its just how windows displays different networks. A hardwired connection will display different than a wireless network. It doesn't impact their ability to communitcate with other devices on your network unless its providing a different subnet of your ip address. you can change them if you want but it requires using a registry edit. Not commenting about your registry skills but you admit to knowing nothing about networking so if its working fine, I wouldn't worry about it.
