PeterM45's avatar
PeterM45
Follower
Dec 30, 2016
Wi fi extender
I have this model installed on the 1st floor and works well extending the signal from the router in the garage. The signal is not good in the office on the ground floor. Can I add another EX2700 there. Will the two extenders work in tandem?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello peterM45
    yes you can use 2 extenders but make sure they are connected to the main router and not daisy chained off each other as you can run into alot of issues doing that.
    DarrenM
