- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in a three story house and I am trying to get full coverage. What WiFi extender can be used with a Nighthawk AX12. The unit is overkill for my internet but I could not resist the price.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The interior walls are cinder block? Or just the exterior.
the RAX120 is a pretty rock solid router. If you can centrally locate it, it should cover 3000sqft without much issues.
Do you have ethernet ran throughout the home? if so, you could connect the Pace gateway in router mode, connect that to the switch, and then connect the RAX centrally located in AP mode.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi Extender
What model is the X12? Looks at the label.
How big is it in square footage? (the house)
What are the walls made of? (certain materials block wifi well)
Can you centrally locate the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi Extender
Thank you for your response. The Model is a RAX120-100NAS. The square footage is approximately 3000 sq. ft. The building material is a combination of cinder block, sheetrock, wooden studs and flooring. The RAX120 is located in the basement under the stairwell next to the AT&T Pace Modem. A Netgear GS116 is used for the ethernet connections. The equipment is located in the basement because the power supply is connected to the generator backup system. The phone lines also connected to a distribution center there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi Extender
Thanks. I am in the process of running ethernet now so I will try and centrally locate the NightHawk, Appreciate your time and response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi Extender
Consider a reliable extender like Netgear Nighthawk X6S for optimal coverage with your Nighthawk AX12. It complements your high-performance router and ensures seamless connectivity throughout your three-story house.
