× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WiFi Extenders
Beastcheetah
WiFi Extenders
My extender stopped working.....i can connect to it on devices and via ethernet cable but I can't connect to the internet. Any ideas on how to fix this? And yes I tried turning it off and on again
Message 1 of 9
Re: WiFi Extenders
Which wifi extender are we talking about? Netgear makes a lot of them.
Message 2 of 9
Beastcheetah
Re: WiFi Extenders
I have no idea. How do I check to see what it is?
Message 3 of 9
Retired_Member
Not applicable
Re: WiFi Extenders
The model number might be on the extender?
Message 4 of 9
Re: WiFi Extenders
It is either on the back, by the ethernet sockets, or on the bottom.
Something like WN2000RPT.
Message 5 of 9
Beastcheetah
Re: WiFi Extenders
DST6501
Message 6 of 9
DarrenM
Sr. NETGEAR Moderator
Re: WiFi Extenders
Hello Beastcheetah
Have you tried to factory reset your extender by holding the reset button for 10 seconds then you will have to do the setup again of the extender.
DarrenM
Message 7 of 9
Beastcheetah
Re: WiFi Extenders
How do I do the setup
Message 8 of 9
DarrenM
Re: WiFi Extenders
Hello Beastcheetah
Here is a article about how to do this and also you can contact geek squad at best buy they do the support for this product.
http://kb.netgear.com/app/answers/detail/a_id/29922?cid=wmt_netgear_organic
DarrenM
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3677 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
