× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WiFi Password Not Working With Extender
corvettesting1
Follower
Extender is connected to router, when I try and connect a device to the extender (with good signal), it doesn’t accept my normal router password. I am using correct password, is the extender faulty?
Message 1 of 2
Guru
Re: WiFi Password Not Working With Extender
What router is it connected to?
What extender do you have?
Firmware on the extender?
Did you install using wps? If so, factory reset the extender and reinstall it using the installation wizard and NOT wps.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 304 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
