× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WiFi Range extender and relibality
DaleH1
I bought a WiFi Range Extender, not for speed but for reliability.  From time to time, I had been loosing connectivity during Zoom calls. Was that a good reason? Will the range extender improve reliability?
Thanks for any replies.
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 3
Accepted Solutions
Guru
Re: WiFi Range extender and relibality
Will it improve reliability? Tough to say.
Its more important to figure out why you're loosing connectiving with your zoom calls.
If its because your device is to far away, then it might help.
If its because of interference, slow internet speeds, sketchy router, then its less likely
Message 2 of 3
All Replies
Guru
Message 2 of 3
DaleH1
Thanks for your reply.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 677 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
