× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WiFi Signal
AleksaDim
Follower
WiFi Signal
Hello,
I am wondering how I can boost my WiFi signal on MacBook Air, I have a WiFi signal that is not full, also every third day I need to put the new UserName and Password, because it is the hotel WiFi, so what device I can use to boost my WiFi.
Thanks in advance for every answer.
Message 1 of 2
alangrin
Re: WiFi Signal
I had the same problem a few weeks ago. The problem can be caused by high level noise from other electronic devices or big distance between the router and the devices. I suggest you to try WiFi analyzer app to identify problem areas with weak signal strength. It's easy in use.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2175 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
