- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi extender trouble
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi extender trouble
The wn3000rpv3 is a n300 range extender. That means is a single band wireless 2.4ghz extender. Many different devices utilize 2.4ghz as it has good range and penatration. Problem is that is lower bandwidth and that it does broadcast so far. this causes interference. As wireless devices get added to your area, so does wireless interference. You can try going in to change wireless channels to see if it helps with wireless interference.
I usually recommend people to download either a pc program (there's free ones) or a phone app to do a wireless channel scan to try to determine the best channel to be on. You want 1-6-11. the other channels might have less broadcasting on them but there's channel overlap. so go for the one with the least amount of devices broadcasting on 1-6-11.
other thoughts is that hvac, foil lined insulation, metal devices (tv backings/etc), do a great job within a house of blocking signals. Sometimes moving extenders to a different room can make a big difference.
Another thing you can check is your firmware. make sure you're on the most current.
